TSL-100 Problems - fixed
Thomaxs
Post by Thomaxs »
Hi There,
i hope i´am in the right Forum.
for the first, this are my first steps in DMX and Freestyler and i searched the Forum and the google search with no result for my problem.
Setup:
Win7 64 bit
Stageline DMX-510 USB
TSL-100 LED scanner
So, my problem is, with the Stageline software i can control the Scanner without problems, Pan, tilt etc.
But the Software form Stageline is not really good and i want use freestyler, it looks very nice :)
ah, my problem:
If i control the scanner with Freestyler, for example pan/tilt, the scanner move to the position i´ve selected in freestyler. But in steps of 1-3 seconds, the scanner (i think) move shortly to zero position and back to the selected posiotion. he dosent reach the zero, so it is only a twitch.
anybody any ideas?
first i think the DMX-USB modul is the problem, but with stageline software these problems are not present.
thank you and good luck to understand my english ;)
greets
Thomas
Thomaxs
Re: TSL-100 Problems - fixed
Post by Thomaxs »
Hi all,
ok, shame on me :roll:
one thing i´ve forgot to try is to change the USB port from my pc.
The external USB Ports from the Tower was the problem. Now the DMX controller is directly connected to the Motherboard USB Port aaaaannnnnd?
it´s running :D
greez Thomas
