I am VERY new to all this and I am looking for a profile for a NW FX Lighting / Passport Par 64 Led 6 channel fixture.
Or help creating a fixture profile where
Channel 1 = Dimmer
Channel 2 = Red
Channel 3 = Green
Channel 4 = Blue
Channel 5 = Strobe
Channel 6 = Shade RGB (?)
Not sure what Shade RGB means. The manual suggests that it is a simple color mixing fader. For the "Shade RGB" channel the manual says dmx address 0-127, 128-191, 192-255. I am guessing that 0-127 is red and so on. Thanks
NW FX Lighting/Passport LED Par 64 Topic is solved
- FreeStyler Version: Beta
Re: NW FX Lighting/Passport LED Par 64
Hej dwebb1911
Here is a good place to start. http://www.freestylersupport.com/wiki/f ... led_parcan.
dwebb1911
Thanks !! Good help there. I have been able to create the profile. But I cannot figure out channel 6.
Channel 6 = Shade RGB. Not sure what Shade RGB means. The manual suggests that it is a simple color mixing fader. For the "Shade RGB" channel the manual says dmx address 0-127, 128-191, 192-255. I am guessing that 0-127 is red and so on. Any thoughts on this. I could leave it out. Not sure it's very useful.
You have to make it as a 6 channel fixture but you don't have to place any control on channel 6.
When you test the fixture then there will be a panel in the right side of FreeStyler with 6 sliders.
Try to play with slider 6 and see what it does. You can the decide what you will do with it.
Note that it may change function depending on the other channels setting.
