Now it comes...how to find the english words...lets see...
We did a lot of work and so yesterday it was the first time to test the f-Version "Live" in the Club.
in the older Version (h) i have made a Fixture for my fogger and activatet "Fixture is a Fogger" to use it with the the Fogger Tool. I can make Makros for it. So i make one for Off. One for Heat and one for Full On.
It is the DMXFogger Control from DMX4ALL with one DMX-Channel.
0 = Off
15= Heat !!!!!
Above are Timers (dont need them)
255 = Fog On
Starting the Makro "Heat" (DMX level 15) and i can use the Fogger tool. It switches to 255 for Fog and releases then back to 15. So the fogger stays heatet. When i want to switch off the Fogger i use the Makro Fogger of (0)
Anything runs fine!
But now in ther f-Version something changed.
At First there is no way to make Makros in the Fixture-Creature.
Then When Setting the Fogger to Heat (15) manualy with the Slider and running the Fogger Tool, anytime when the tool sets the Fog-Level to 255 and releases it it does not come back to 15. It goes to o so the Fogger is OFF and cooles down...
so there is no way to use the Fogger-Tool.
is it a bug or did i do something wrong?
Withe the DMX4ALL-Interface you need the ability to set the Fogger to 0 8Off) and to 15 (Heat). And if you want Fog then to 255 and back to 15. To switch off to 0.
Hope you understand what i mean.
Greetings Kai-Uwe
Fogger Tool with problems... Topic is solved
lj_raph
- FreeStyler Developer
- FreeStyler Version: 3.2.1
Re: Fogger Tool with problems...
Hi
I did make some changes, I added a min max value for each channel specially for this problem.
Edit your fogger profile in the fixture creator and fill in the min and max values.
Best regards
Raph
Best regards
Raph
Kai-Uwe
i think i am blind but...
when editing my "old" Fogger Fixture-File (DMX4ALL the File is named fogger.fxt and delivered with Freestyler)) there is no place to set a min or max channel. Also the Point "Fixture is a Fogger" is no longer there. ( Remember it wasn't a special Fogger Fixture. You have to mark "Fixture is a Fogger".)
When creating a new Fixture there is also no min or max channel to set in the Creator. All i can do is to set the Fan and the level Channel and the Number of Channels.
The description of the Fan Channel ist not absolutly clear (signed with "Fog / level ch.") so i tried out 1 (For the assigned Fog-Channel) and later 1 / 15 (For the assigned Fog-Channel an min. level). But i also did not work.
Yust for your Info: I have switched to the i-Version with the 3.96 Fixture creator.
At this time i have "helped" me with my old original Fogger-Fixture. When i need the fogger i set the level to 15 manually in the Slider. So the fogger heats up. Than i can use the Fogger tool without problems. Then it dont "jump" back to 0 and switches the Fogger of. It only jumps back to 15 and the fogger stays heatet and ready. To swich them of i have to manually set the Slider to 0.
Oh good my bad english. But i hope you understand what i mean.
Greatings Kai-Uwe
Greatings Kai-Uwe
