I have a set of moving head fixtures that I want to limit their movement to just the front of the fixture. I understand how to set limits in the fixture profile however these limits aren't exactly what I have in mind.
I mount my heads, Chauvet MinSpots, on a T-bar hung with the head down. So all I want is forward movements so that the light doesn't rotate more than 270 Left to Right, and 180 Up to Down, with down being nearly straight down. How do I do this?
Limiting Movement on Moving Head Fixtures?
jokerswild
- FreeStyler Version: 3.0.1
- Spirit
- FreeStyler Version: 3.5.9
Re: Limiting Movement on Moving Head Fixtures?
Hello, do you mean something like this?
http://www.freestylersupport.com/wiki/s ... references
and search for "Pan/tilt Resize"
jokerswild
Looks like that would work if I create cues for movements.... what I was hopeing for was a general setting that even on sound active would limit the movements to the forward side....
- musicboy71
- Just started using FS
- FreeStyler Version: 3.2.2
I limit the movement in the fixture itself, not the software. This is using Q-Spot 260's. The nice thing is that I can program as normal in FS, and the heads will adjust based on the limits I set on them. If I change the limits - I don't have to change the programming.
