Problem installing BCF2000
DjMania
Post by DjMania »
Hi!
I’m trying to install the BCF2000 but I have no success and now I don’t have any more ideas. Please help me! :-)
I powered the BCF and connected it to USB. Windows say that it have found new hardware and installed it correctly. But BC manager says that there are no controllers connected.
I have tried to change USB port and cable with no success.
I have installed Behringers MIDI drivers.
I have no more ideas so please tell me what I have missed. Thanks for your help.
Re: Problem installing BCF2000
hello, Djmania
did you allready put your bcf on USB mode and BC mode
http://www.freestylersupport.com/wiki/using_bcf2000 here you can read how to do it.
DjMania
Post by DjMania »
Yes, both BC mode and U1 mode. I have checked and changed it several times. Still no luck :-(
ai , difficult.
did you also tried a other pc.
and can you also explain what you allrady did with bc_edit and how you tried to connect your bcf to bc_edit.
does the bcf2000 work with freestyler (with the default .sys file) ?
DjMania
Post by DjMania »
To be honest I don’t have a clue what I did wrong, but now everything seems to work. :-)
I tried to install BC Manager on a second computer but didn’t get it to work there either. But then I realized Freestyler recognized the BCF. I downloaded Bome’s SendSX and transferred a .syx file to the BCF and installed an .fms files in Freestyler. Everything seems fine, but I have a lot to learn.
Then I deleted the BCMan.ini file and started BCManager again. Now that program seems to work also.
Thanks for your help. Now I have to start learning. :-)
Return to “BCF2000”
