On this page I will discuss the use of Behringer BCF2000 midi controler with FS.
This device is probably the most cost effective and versitle bits of kit that any FS user could invest in.
This is not ment as free advert or endorsment for any product but as it is such a popular device I belive that its inclusion on the wiki is an important one.
Before using this device, make sure it is running in the “bC Mode” emulation. It should be by default.
To change the mode:
Switch OFF the BCF2000
Push & hold the desired mode button (upper left corner, button with “bC” as description)
Switch ON the BCF2000 and wait until the selected mode is indicated in the display
Release mode button
USB mode 1 (U-1) is used for controlling software via USB (like Freestyler) and disables all the MIDI ports on the actual BCF2000.
Note: If this is not your desired setup, please refer to the BCF2000 user manuals for setting your desired mode of operation.
Push & hold the EDIT button on the BCF2000, and press STORE button at the same time.
Release both buttons
Select U-1 by turning the “PUSH ENCODER 1” (uppermost left corner knob) until “U-1” is shown in the display area.
Push the EXIT button
Found these on two different threads on the forum.
BCF2000 Configuration File:
Freestyler.syx (optional - not needed for FS operation)
Behavior: unknown
fs_setup syx.zip (optional - not needed for FS operation)
Behavior: comprised of 5 presets. Each preset only changes the channel numbers for the faders. All other buttons and encoders remain on the same channels for every page. - (This file was created by dmxlighting, this is my pesonal setup for the BCF for use in FS, contact me via the forum for more info)
BCEdit -
BC-Edit_02beta3.zip
Use BCEdit to create your patch and Export the ”.syx” file. Then use SendSX or MIDIOX to upload it to the BCF2000.
Note: BCEdit has a function built-in to transfer the .syx file to the BCF2000, but it only works with certain versions of JAVA (JAVA 1.4?). To be on the safe side, use either SendSX or MIDIOX.
MIDIOX -
http://www.midiox.com/ -
Windows
Software to monitor MIDI data. It is also useful for transferring ”.syx” files to the BCF2000.
