Prolights CromoBeam 250
Boguy
- FreeStyler Version: 3.3.2
I've tried to make my CromoBeam 250 fixture for Freestyler but it doesn't work. I don't know why. Can somebody help me on this fixture, please? Tanks to all.
Boguy
Re: Prolights CromoBeam 250
Sorry, I've forgotten to add this capital (?) info. It can be the same with the Showtec Indigo Beam fixture, I'm not quite sure. So If anybody has this fixture, it can help too.
And here is the DMX descrisption attached.
- Spirit
- FreeStyler Version: 3.5.9
can you discribe you issue.
so i can help.
so i can help.
Boguy
So, there is no response from the Cromobeam when i try to control it buy dmx. I don't know if it's a problem with the dmx on this Crombeam (i have two of them and it's the same problem) or the problem is with my fixture.Spirit wrote:can you discribe you issue.
so i can help.
If anyone can try the fixture and tell me if it works or not. Or look after the fixture and tell me if there is any problem with it.
Thank you again, guys.
Boguy
Hi guys,
I've spend a lot of time on this and it works now. I've tested it and it works fine.
CromoBeam250tested.pff- Cromobeam 250 Fixture works fine tested
- (83.51 KiB) Downloaded 77 times
- Spirit
nice everything work grat now.
can you also explain what you did wrong?
Kind regards, Spirit
Boguy
The issue was from Cromobeam. But it ok right now as i told.
