uDMX on Windows 7
jplighting
uDMX on Windows 7
Post by jplighting »
Hi guys
I've been using Freestyler all year, and it's great! I have a uDMX usb to dmx converter, which works fine, and a while ago my laptop died (Windows XP) so I was using my dads for a while (Windows Vista D:) and now I've got my new one which is Windows 7, and I've installed the driver correctly (I hope) but its not working! the red LED doesnt light up... Has anyone had something similar happen? How do you get it working on Windows 7?
Cheers
Re: uDMX on Windows 7
it could be because its 64bit windows and it may not be a 64bit driver :(
jplighting
I uninstalled the driver and re-installed it, and it comes up with this message...
"Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)"
I assume that's bad :(
did you download the driver? it just sounds like it hasn't downloaded properly and so you would get that message re-download it or if it was on a CD re-download a new version from there site for windows 7...
jplighting
yes I downloaded it, however I have found a different site (in chinese) which apparently has an updated version of the same driver, so I am downloading that. Hopefully it will work! Cheers
chinese? be careful only get drivers from the manufacturers site a chinese version may be incompatible with yours!
jplighting
the site is where the manufacturer got the driver from originally... it's just an updated version from a different link... I hope... :/
jplighting
ok so the download gets halfway done then fails... have emailed the guys I bought it off... fingers crossed... :/
jplighting
UPDATE: So apparently the driver is incompatible with Win7 64-bit... I'm looking into an updated version of the driver or an emulator for a 32-bit system... hmm...
Röschi
FreeStyler Version: 3.0.1
Post by Röschi »
jplighting
THANKYOU SO MUCH!!! :D
You've really saved my ass haha
Cheers
l2net
FreeStyler Version: 3.2.2
Post by l2net »
Your uDMX controller works with newer versions FreeStyler?
arulguna
FreeStyler Version: 3.5.4
Post by arulguna »
Does anyone have a copy of the 64 bit driver?
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
arulguna wrote:Does anyone have a copy of the 64 bit driver?
Röschi wrote:I'm running my uDMX on my Win7 64bit System! After searching the web and contacting a developer I actually found a modified driver for 64bit.
Please PM me, so I can send you the driver together with an installation manual.
Contact this person and he should be able to give you one, Arugula! :)
Send PM Message to Roschi
Sassscott
FreeStyler Version: 2
Instagram: Sassscott Ent
Post by Sassscott »
Hi I was wondering if you can help me out as well please ,with a location or file for Win7 64bit uDMX driver?
Scott
sassscott@gmail.com
Return to “DMX Interfaces”
