TRI LED - Starville
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
TRI LED - Starville
Post by matt »
This is the fixture file for the StarVille TRI LED. This fixture file is for DMX mode 4 ONLY.
- Untested..
uses the RGB Segment feature
Stairville TRI LED.pff
(2.54 KiB) Downloaded 390 times
Matt Hankosky
flickr.com/photos/mattxhank
matt
Admin
Re: TRI LED - Starville
Post by matt »
Make sure you set to Mode 4.
You can control the devices individually via your DMX-controller. Press
“MODE” button until it shows , this means DMX address is 001, you can
set the DMX address by “UP” and “DOWN” buttons. If press “SETUP”
button, it will show d-p1, it means the device is in which DMX mode 1. You
can switch these DMX modes by “UP” and “DOWN” buttons. There are 7
DMX modes.
Matt Hankosky
Risingscale
Re: TRI LED - Stairville
Post by Risingscale »
Here is the shot
I'm waiting for my enttec dmx usb pro to test the file.
Thank you very much Matt.
Phi
nomic
Post by nomic »
did you test it?
how it works?
you need to have 5 fixtures for eatch Stairville Stage TRI ?
how do you adress the dmx if you can only adress one dmx adreess to eatch Stairville Stage TRI?
i am very newbie... and a bit confuse....
Return to “Stairville”
