All lights turn on after program exit
cameronbudge
Post by cameronbudge »
ok so i think i have narrowed it down the the entec open dmx interface, thought it might have been freestyler as i have been changing over to it from manalator but now i find it does the same thing after i exit manolator
All lights are OFF then when i exit the programs they all turn back on and the mirrors etc go crazy so i am assuming they are all getting 255 on the dmx inputs
has any one had anything like this??
regards,
cameronbudge2
Re: All lights turn on after program exit
Post by cameronbudge2 »
ok so now i have narrowed it down to the acme invincibled light i had added, it looks like when no dmx signal going to it it sends out spurious data - thus jands fpx all channels turned on, martin roboscan 518 mirror go crazy sounds like they are being driven way past their comfort zone...
If i turn all lights off in program then pull out dmx cable from open dmx exit program, all is fine, nothing turns on
if i turn all lights off in program leave dmx cable in lights turn on when program exits
i know this isn't the best but if turn all lights off pull out usb from open dmx exit program all ok but if refit usb to open dmx lights turn on
any one have any ideas or had anything like this???
dodgy opendmx interface???
acme invincibled light?????
also not sure if i mentioned am doing this on a xp computer, have tried a win 7 machine with exactly same result
regards cameron
sirwesley
FreeStyler Version: 3.5
Post by sirwesley »
Some of my lights do turn back on. Haven't figured it out yet either.
Return to “DMX Interfaces”
