Custom color presets Topic is solved
russellcframe
Post by russellcframe »
In using LED Par cans I love the ability to mouse around on a color pallette to select colors in real-time.
It would be great if I could save off colors I like to a group of custom color presets that I could easily save later from the color pallette window.
For example, finding a white that I like is difficult with LED cans, once I get one it would be nice to save it for later use in different sequence steps.
Thanks.
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Re: Custom color presets
Post by matt »
Use Macros...
Matt Hankosky
flickr.com/photos/mattxhank
matt wrote:Use Macros...
your so usefull.....
matt
Admin
Post by matt »
ok.. You Should Try and Use the MACRO function in the Fixture Creator! Or you may also want to make Cue's for the different Colors.
Matt Hankosky
Tom
Post by Tom »
As far as I am aware you have to know the values to create macros though? And it has to be done in fixture creator? See my thread on palettes.
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
yes i agree totaly white is a difficult one to get on led fixtures.
I suppose this could be done in two ways simple and the not so simple.
1. the simple idea would just save the RGB/CMY values and would operate like any other colour in the colour picker I.E the colour is saved in the sequence.
2. NOT so SIMPLE.
Works like a real pallet, sequences reference the pallet therefore if you alter the pallete it updates all the sequences.
Return to “Ideas and Remarks”
