ADJ Color 250D file? Topic is solved
Johnson Unit
Post by Johnson Unit »
Hi all- brand new here. Just got my Enttec Open USB and 5 pin adaptor in the mail yesterday. I found fixtures for my Intimidator 1.0's and my PAR 64 LED's but nothing for the ADJ Color 250D's. I tried to make one in the fixture creator to no avail, I even tried to find similar color changer fixtures from the library but none would work. This seems to be a fairly common fixture and it's still in production. Anyone have a file for it?
Also, how do you get a dimmer pack to work? I made a file for my simple Eliminator ED15 but it has no controls, neither do the stock ones from other manufacturers... I have some conventional PAR 56's and some Halogen blinders I'd like to control with it.
Thanks in advance! :D
Johnson Unit
Re: ADJ Color 250D file?
I'm also looking for ADJ 64B Led Pro. Again, not on the list. I have found a few other LED 56 that will controll it but would like the real deal!
Johnson Unit
Here are the pdf files if anyone is willing to help out.
Thanks again.
http://www.americandj.com/pdffiles/64bledpro.pdf
http://www.americandj.com/pdffiles/Color250D.pdf
Johnson Unit
Any one take bribes here? Paypal?
Mavi
Post by Mavi »
Hi there, and sorry for this late reply. The best way to create fixture files is to do so on your own. There is a realy simple reason: you have the fixture at your side. An other reason is, you will not have to pay someone for doing the fixture file. The user in this forum will provide you help for free, if they can.
To get startet with fixture creator read in the Wiki about it: http://www.freestylersupport.com/wiki/fixture_creator
If you already have some worke done, it would be nice if you can provide the current pff file (chose "export" in fixture creator) so we can take a look and try to find your problems.
Let's start with the simple dimmerpack. You can crate dimmerpacks in fixture creator but most user do not like it. The problem: you can only define one intensety channel per fixture. But the dimmer has some more. Intensety channels are use for master blackout so you want every channel to be defined. The solution: use a simple one channel PAR can for each dimmer channel. You will finde lots of theme in the fixture list. Be sure the addressing is done right! If you have a 4 channel dimmer with start address 5, you will add 4 simple par cans, first with address 5, second with address 6, third with adress 7 and fourth with address 8.
Not to the other fixtures you asked for. As I said already it is hard to finde your problems without a better discription what is not working (and what is) and without the current pff file. Please discribe your problems better and upload the pff files and I will help you to get this fixtures work.
Shannon D
Post by Shannon D »
I'm in a good mood today, so I created the file for you. It's not tested, as I don't have this light. I hope this helps solve some of your problems.
Cheers!
SD
ADJ Color 250D.pff
(29.49 KiB) Downloaded 38 times
Johnson Unit
Thanks so much Shannon, I'll try it tonight!
