Mojo/Geni Spin Master I
YeTTi
FreeStyler Version: 3.3.2
Post by YeTTi »
Hi all,
does anyone have working fixture files for this?
Nothing seems to exist in the fixture list and I know I should go ahead and try making the fixture myself, but Im sure these must be quite common so would have thought some one would already have them setup. Also, I have no manual which doesnt help.
or.. are there any alternatives?
FreeStyler Version: N/A
Re: Mojo/Geni Spin Master I
Post by remco_k »
Moved fixture requests.
YeTTi
Post by YeTTi »
Ive started setting this up in ficturecreator and doing pretty well, but I have a problem.
You can spin the mirror clockwise and anti-clockwise, much like you can control a scanners mirror. this is transmitted on channel 2 between values 0 and 111. If you go beyond that the scanner spins itself automatically at varying rates in either direction depending on the value.
How can I set it up to be able to control the manual turning of the mirror via the x-axis but only in the range of 0 - 111?
is this possible?
Mavi
LJ
FreeStyler Version: 3.2.8
Post by Mavi »
Try to enter the channel as a gobo channel. Then you can define values from slow to fast as you want. You can controll the spinning by hiting the specific gobos then. You can also use macros to controll the spinning speed with pre-defined values. But I think there is no way to limit the maximum for an channel. It is always a problem if a fixture uses one channel to control more then one function.
ghogho
Post by ghogho »
Also have - MJS-3 ELC (Mojo Spin Master III)
Anyone create custom fixture for it?
