STAIRVILLE LED BAR 252 RGB Topic is solved
power-button
Post by power-button »
Hello,
looking for the Fixture for this device... or can anyone help me creating one ???
thanks
power-button
Re: STAIRVILLE LED BAR 252 RGB
i would have made a Fixture setting on my own, but the problem is, that the device has got 3x RGB colors... I don't know how to set up... ?!?
Edit:
using my own Fixture, Freestyler does not black out the device... :?
take a look :geek:
LED Bar.pff
(31.93 KiB) Downloaded 425 times
FreeStyler Version: N/A
Post by remco_k »
power-button wrote: using my own Fixture, Freestyler does not black out the device... :?
Fill in the shutter channel (2) on the "fixture config" tab.
Enter the open and closed value for it and FreeStyler does black it out.
If it for some reason does not you can consider creating a blackout sequence. Create a 1 step sequence where you blackout all your fixtures. Add it to the override buttons and you have created yourself a custom blackout that works and does it the way you want. (e.g. keeping background or stage lights still on).
power-button
aaah yes, I understand :)
but it is channel 1 for "back out"
channel 2 is only for speed...
When I solve the problem with the 9 color channels, I have made my first working fixture :)
Is there anyone, who can help me on this ??? PLEASE ;)
rock on
Jens
Post by remco_k »
power-button wrote:aaah yes, I understand :)
You need to set channel 1 fixed to 41 ("3 segment mode") and never change it. Then channel 2 is the shutter for all the 3 RGB's. At least, thats what I assume looking at your image posted earlier.
power-button
That is no option for me, because I just bought this Device because of the Chase function with the 3 segments. With 4 of them its a great effekt.
(DEUTSCH : Das ist keine Option für mich, ich hab mir die Dinger eben wegen der Lauflichtfunktion der Sekmente gekauft. Mit 4 Stück kann man nen geilen Effekt machen...)
rock on
power-button
so this is my final fixture
:fs:
Stairville LED Bar.pff
(31.93 KiB) Downloaded 793 times
well done dont forget to post it in fixture files download section ;)
Post by remco_k »
Thats a good reason.
Still you can start with the default value at 41. Also create a macro that sets that channel.
Then you can use the 2nd channel as shutter.
Another way is what you currently have done by setting the shutter channel to 1. Thats a clever one.
I gues dimming is not possible this way (by using the shutter or intensity controls in FS).
But it might be more clear to give the channel the 'function' name - as it still shares different functions. But thats just a small name change. It wont affect any controls.
Either way, with this fixture it will be the one problem or the other. Its just a choice which one is the best to use. :)
Another way is something already opted earlier:
Create multiple fixture files for this fixture.
Fixture 1: "LED BAR 252 Master" (controlling channel 1...5)
Fixture 2: "LED BAR 252 Sub" (controlling channel 6,7,8)
Fixture 3: "LED BAR 252 Sub" (controlling channel 9,10,11)
Fixture file 2 & 3 are the same, so you have to create one fixture file for that.
But now don't fill in the shutter values, but do enable the RGB option and fill in the RGB channels. FreeStyler will then be able to dim all the RGB channels.
When adding this fixture to FreeStyler, lets assume you addressed the fixture to channel 11. Fixture 1 should be added at channel 11, fixture 2 at channel 16, fixture 3 at channel 19. Its not easier to create + install, but the way it works might be.
wizofreak
FreeStyler Version: 3.5
I Use FreeStyler for: Theater
Post by wizofreak »
Hey,
Power button first thank you for your work, I have your fix a little bit and edit the colors have added. Now it is possible to select all the colors!
greet wizofreak
:fs:
LED Bar.pff
LEDBar PowerButton Fix
(32.35 KiB) Downloaded 213 times
