First have you tried? Log in to Search the Forum for help! Learn more about using FreeStyler at the FreeStyler WIKI HERE
1. Open fixture creator -> Other
2. Fill in manufacture Name and Fixture Name
3. Select a fixture picture or create your own
4. Total Channels = 3
5. GoboCh1 = 2 n' gobos = 10 (This will be channel 2 chases)
6. Goboch2 = 2 n'Gobos = 15 (this will be for patterns)
7. shuter ch = 2 closed = 0 (blackout)
8. strobe ch = 3 off = 0 low = 63 med = 126 high = 255 (you may need to play with these to get the desired speeds)
9. goboRot1 = 1
10. Channel descriptions -> enter the descriptions from the manual
11.1st gobo wheel. (chases) chase one you would need to enter 160 as the dmx value, then select 1.bmp from the sidelist
chase2. enter 170 and select 2.bmp using the dmx values from the manual for each chase and selecting an apropriate image from the list.
so this for all the chases.
12 2nd gobo wheel. same again for this one. starting at patern1 enter 10 as the dmx value and 1.bmp for the image.
13. save the fixture
14 import into Freestyler
15 test
16. If everything works fine, upload the exportet fixture file to the "FreeStyler Fixture Files - User created Downloads" forum. So others looking for the same fixture file in the future can use it.
