Moving everything to another machine
Crrispy
- Bug Zapper...
- FreeStyler Version: 4.1
Hello,
I'm starting to learn FS on may main PC, building fixtures, sequences and so on, including Magic 3D easy viewer (great tool!) .. now when I want to migrate on my notebook for live use, which files/directories do I need to copy? Is everything located in the FS directory and subdirs? Does FS use registry entries?
Thanks.
Thanks.
Jaykie
Re: Moving everything to another machine
FS has a backup/restore function, it's located in File->Backup/Restore. I believe that if you copy the backup file you get to your notebook, you have all your files back... don't know for 100% sure though...
Crrispy
- Bug Zapper...
Thanks, I see that you "can now teach FS to others", LOL! Will try that and see if it exports really everything (I doubt about the 3D viewer stuff but I only need it on the main PC to program/test, so..)
- djSupport
thats automatic... (after 80 posts) he might be useless lol! maybe i should change that!Crrispy wrote:Thanks, I see that you "can now teach FS to others", LOL! .....
- djSupport
i understand wtf! but not that...... wtf?
Jaykie
just a typed version of a sound you make when you're annoyed
- djSupport
er aha grumble....
- djSupport
hmpfffffhhhh
matt
- Admin
- FreeStyler Version: NULL
ugh...
Matt Hankosky
flickr.com/photos/mattxhank
Crrispy
- Bug Zapper...
Well, I zip the whole directory, unzip on the notebook over the existing installation and it works fine. Of course also transfers the 3D viewer fixtures, stage, etc... so everything in 1 step.
