I made the following tests :
1/ Change screen resolution :
Tried 800*600, got a warning message, but the software started: same issue
Tried 1024*768, got no warnig, software started: same issue
2/ Uninstall Freestyler and Reinstall
run in 1024*768 : same issue
As I'm a player, I also tried in landscape and Portrait, but the same appears.
NOTE: I'm using Windows 7 pro 64 bits on a DELL Studio 17"4 Multitouch
Let me know how I can further help
Laurent
dmxlighting wrote:OK I see the problem now but I don't think its the resolution of the screen.
But to see if its a factor please setup the res to the lowest you can, for example 800x600 and see if you still have this weird problem.
Other than that try resinstalling FS.
If I remember correctly FS is not normally affected by the screen resolution.
