Fogger Control? cleaver!! Topic is solved
yofo
Post by yofo »
How does the Fogger Control know there the fog machine is located at, because I just have to add my homemade fog machine fixture, and everything is on 0 default, but if I click on the Fogger Control, manual fog button, it makes fog? :? how does that work? I don't even have to move the sliders? lol
Re: Fogger Control? cleaver!!
Post by LJ_krede.dk »
yofo wrote:Hi,
i don't understand what you are saying? it sounds like it does what it's should... when you add a fogger fixture to a specific DMX address, FS knows there is a fogger on that address. so simple as that!
yofo
Post by yofo »
I just added my fixture, and without moving any levers on my DMX-3F that is connected to my fogger, I just click on the fog button in FS, that is circled with red, and if I click on fog, and just makes fog, but I haven't even touched my fogger machine settings, like for example, ch1 is on / off, that Fogger Control controls it all. I don't even have to make my own macro's for my fog machine fixture
untitled.zip
(54.87 KiB) Downloaded 72 times
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
freeStyler sees the fogger fixture and works out its addressing from that.
The fogger control is linked to the fixture and no the address.
yofo
Post by yofo »
Mattotone wrote:freeStyler sees the fogger fixture and works out its addressing from that.
It's a awesome feature tho...... :fs:
yofo
Post by yofo »
Does anyone know if FreeStyler allows for multiple foggers on differing addresses to be controlled by the fogger control ????????
I know it is possibly a silly question as if you are using the fogger control they all would be working at the sametime anyway, but what if you was also controlling them from within sequnces/cues ???
That was going to be my next soon to be question....
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
An interesting thought!
yofo
Post by yofo »
how about put all the foggers on the same DMX starting address? :?
Well, onge... you can answer your own question by trying it out;)
i have tried it for you. If you have several foggers/hazers on different addresses they would all be controlled by the fogger control.
yofo
Post by yofo »
LJ_krede.dk wrote:Well, onge... you can answer your own question by trying it out;)
hehe, sounds cool, I only have one fogger tho :?
