Guys,
Im Using Freestyler 2.96 and a JMS USB2DMX Interface,
but I cant for the life of me get my Soundlab Colourscans to react to DMX!
Initially i thought it was a problem with the fixture as all my other fixtures work fine, so i got a new 1 and it wont react either!
The fixtures react to a DMX signal from another colourscan, but not from the interface. The addressing is good, I've checked it over and over!
Any suggestions??
Thanx in advance.
Soundlab Colourscan not reacting to DMX Topic is solved
- remco_k
- FreeStyler Version: N/A
Re: Soundlab Colourscan not reacting to DMX
Maybe (if above is the solution) its better to open the colourscans and make the wires of pins 2 & 3 cross internally.
humek
Heading up to the DJ shop shortly for some new DIP switches (as I thought this could also be a cause), so I'll pick up a couple of XLR patch leads to modify while im there!
This is the only thing iv not tried!
Standby for the results.............................
humek
GREAT SUCCESS!!
Made a patch lead this afternoon from a cheap XLR lead and all works fine!
The warrantys up on the lights anyway so ill open them up an get the wires on the DMX connections swapped round.
Many thanx for the help folks!
P.S Bought myself a new laser this afternoon aswell
