I Use the Enttec USB Pro dmx dongle with freestyler and an SM 16/2.
After i close the software, the enttec pro is not released.
Is it possible, (mabey in a selectable setting of freestyler, that it releases the Enttec usb pro DMX? (or disconnect contact with the comport it uses ?)
So that dmx true becomes active to use an old style slider panel?
Best reg, Bob
Release of Enttec USB pro after closing freestyler.
- cyberb0b
- Commited FS Forum helper
- FreeStyler Version: Beta
- remco_k
- FreeStyler Version: N/A
Re: Release of Enttec USB pro after closing freestyler.
I use the Enttec Pro also. FreeStyler disconnects from it the way it should. It is just the Enttec Pro that keeps on going...cyberb0b wrote:I Use the Enttec USB Pro dmx dongle with freestyler and an SM 16/2.
Best reg, Bob
As far as I'm concerned, thats the great part about it.
When starting another DMX softare package, it should be able to connect to the Enttec pro and use it as normal.
Could you explain your problem somewhat better?
- cyberb0b
To explane it some better, (i Hope)
My setup;
pangolin ILDA dac with dmx out >> "dmx in" enttec pro >> "dmx out" enttec pro >> fixtures.
When the led on the enttec is disabled, it relays info from DMX in to DMX out, so i don't have to switch cables.
When i use the laser software to control my dmx network, i have to "disconnect" the enttec pro.
Mabey its an option that can be included in the advanced settings of the enttec pro USB DMX. A sellection to release the controller so that it will go to relay mode.
Best reg, Bob
My setup;
Best reg, Bob
- dmxlighting
- FreeStyler Version: beta
Not really sure what or why your set is doing but the DMX in of an Enttec Pro does not work with FS.
The only dongle that has a compatable DMX In is the Martin Professional dongle.
- cyberb0b
You read me incorrect.
Thats why i want to release the usb dmx pro connection, so it relays the dmx info true.
- dmxlighting
I think I get it now.
What you need is a DMX combiner. Look at this link - http://www.thomann.de/gb/botexdmx_merge_dm2512.htm
This will allow you to use FS and a desk without needing to release the enttec unit.
Hope this helps
Hope this helps
- cyberb0b
Thanks for your advice,
Ill take it in consideration. Every penny is one
Best Regards,
Bob
Best Regards,
Bob
- remco_k
I think I get what you want:cyberb0b wrote:To explane it some better, (i Hope)
My setup;
Best reg, Bob
When you use FreeStyler, you want the Enttec USB DMX to output the 'FreeStyler signal', but when FreeStyler is shut down, you want to let the Enttec USB DMX relay its input to its output. Right?
And the Enttec USB DMX only relays the input to the output when the led on the Enttec is not flashing, I understand from you, right?
If both options are true, it has noting to do with FreeStyler. FreeStyler releases the assigned comport to the Enttec USB DMX pro properly. But it is the Enttec USB device itself that keeps on running on its own, it has a build in processor, so it is capable to do that, until power is lost (USB plug disconnected).
If you need to relay the input to the output, just make a simple hard switch yourself, so your Enttec get bypassed completely?
Or unplug (and replug) the USB cable quickly.
- cyberb0b
Thanx for all your reactions,
I think the best way to go is with an DMX merger, as suggested above.
Than i can give the ILDA laser dac dmx out a higher priority than the enttec.
So i have no need to switch cables at all.
