why will the freestyler 'sound to light unit' not find my external sound card a 'Maya EX7'
I was told that this would stop PC crashing, but no matter how Itry, I cannot get unit to find soundcard, it will only detect PC's internal card which, while I'm DJing is not in use?
All help welcome and greatfully so....
Goochie
Sound to light ???
Goochie
- FreeStyler Version: 3.5.5
- remco_k
- FreeStyler Version: N/A
Re: Sound to light ???
Does windows itself see the Maya soundcard? Did you install the driver?
Can you play / record audio with it with other software?
If one or all of the above is answered by 'No' then there is a source of your problem.
Furthermore I don't see why an external soundcard would stop a PC from crashing. Seeing your other topics I'd think you have a old slow PC, or bad hardware.
