Hey everybody
two quick questions:
is there anybody who knows what the "shift function" for midi is doing?
there is also a "shift" button at right side of the midi control window in options, see attached picture. what is that good for?
thank you in advance
the shift function Topic is solved
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: the shift function
Im not sure how to explain this clearly,
On Midi controlers you may only have a set number of faders, buttons etc.
So page's where introduced so that changing the page changed the function of all the buttons/faders.
The shift button only changes the function of faders/buttons that have an alternative shift function for as long as the shift button is held down.
much like the shift button on your keyboard.
MATT
MATT
ahhh, i seee. i did know about the pages but I did never found out how the shift function worked,, nothing happens if a pressed the assigened button
thats actually a great feature, makes my job a lot easier
Thanks for the response
