At Laser Pisces - Need FreeStyler files!!??? Topic is solved
paulskyhines
Post by paulskyhines »
HI all,
This may be a noobish question. Just bought a At Laser Pisces - http://www.atlaser.hk/en/pro-detail.asp ... 134&id=539
Just couldnt see them in the FreeStyler library when i went to add it to my current setup.
Any one gotten one to work ok freestyler?
Thanks All!!
Paul :fs:
Android Dev (Moderator)
FreeStyler Version: BETA
Re: At Laser Pisces - Need FreeStyler files!!???
Post by Mattotone »
Although most fixtures people make will be posted on the forum, i bet their is a fair few that are not.
We need to stop discouraging people asking if members already have files.
The users are not asking if we can create a file for them, there asking if there is one readily available, There's no point reinventing the wheel.
Now however if a user is asking for a member to create one for them, is a different matter.
Fixture files are very easy to create, the images can be a little time consuming thou.
As long as you remember that not all attributes of a fixture may be catered for.
I.E LASERS, theirs a lot of functions that lasers carry which freestyer does not have a place holder for, and sometimes a little ingenuity is required E.G A channel to make the image larger or smaller,
IF you have your patterns assigned to the GOBO Channel, you can use the gobo rotation channel to adjust the size of the patterns.
Multi ringed led par cans also seem to be a problem for most users as freestyler only supports 3 channel rgb, fixtures that require 6 or 9 will either have to use faders for the rest of the channels or pach the other channels together in Freestylers fixture setup.
paulskyhines
Thanks for the help, will give it a go, just new to DMX and FreeStyler :-P
Paul :-)
