Stairville PAR56
Android Dev (Moderator)
FreeStyler Version: BETA
Stairville PAR56
Post by Mattotone »
Stairville PAR56
Stairvile Par 56 LED.pff
(11 KiB) Downloaded 276 times
cantyco
Re: Stairville PAR56
Post by cantyco »
I think you missed typed the subject as its a par 56, but thats just a small note.
If anybody buys the Stairville PAR64's like i ahve the 56 fixture file is identicle, and as i just proved works perfectly fine with my new ones :) lol
:fs:
Hi Mattotone just wondering if you had made a scan libary entry for the par 56 for easyview? i tryed to make one, but i can;t find out the correct way to setup channel 1, set it up like a dimmer the same way freestlyer handels it but that only shows the colours when on full which isnt correct really...?
any help would be appriated..
Post by Mattotone »
When i created the fixture, i set ch1 as an intensity channel with the range of the manual function.
This is so i could use it with the DMX400
easyView Settings
number of channels 5
liabary type par 56
beam angle 30'
CHANNEL TYPE NAME
channel 1 Free Function
channel 2 RGB RED RED
channel 3 RGB BLUE BLUE
channel 4 RGB GREEN GREEN
channel 5 FREE Speed Functions
cantyco
Post by cantyco »
Thanks Matt,
I figured it, its cause i set it up as a dimmer channel to start with, and then i changed it but didnt realise had to take the light out and put it back in easyview.
kikabyte
Post by kikabyte »
Hi, for the sake of saving me a few mins,could someone forward me the Easyview file for these pars, or upload it here.
Thanks in advance
Chris
cantyco
Post by cantyco »
yeah i should be able to do this when i get to my laptop tonight.
Tim
cantyco
Post by cantyco »
Hi, it wouldnt let me upload the ssl file.
If you pm me with your email address i'll email you it.
is that the correct extension for easyview files?? is that a bit like the exported fixture files of fs?? (dont use easyview 3d as you can tell lol) if it is I'll add it so you can upload those files.
cantyco
Post by cantyco »
as far as i know it is... there isnt an export in the scan libary so i assume it is the exported file version
Return to “Stairville”
