Is the shape generator working O.K in version 3.0.1 ?
When I press "run" nothing happens. I can work it O.K in the older version.
Cheers, Dek.
shape generator
dekw1
- FreeStyler Version: 3.5
- I Use FreeStyler for: None of your damn business!
shape generator
Un gel spГ©cial est utilisГ© pour aider si vous avez vasculaire cГ©rГ©bral et de crise cardiaque.
- djSupport
Re: shape generator
Someone has posted a bug report on that if its not you then it may seem that way!
bcondemi
Re: shape generator
So is there a patch to fix the dot so that is moves when activated? because it dosen't work now
BC
BC
lj_raph
- FreeStyler Developer
- FreeStyler Version: 3.2.1
Re: shape generator
Hi All
This is not a bug, it has been disabled because it delayed the shape system (fixtures not in sync).
Best regards
Raph
Best regards
Raph
Raphaël
bcondemi
Re: shape generator
Any idea when it will be fixed?
Can it be enabled? If the fixture is not in sync, It doesn't bother me but I am able to tell that it IS working at a glance; and what shape its currently following...
thank-you
BC
thank-you
BC
MarSafe
Re: shape generator
Well, that's the easy part: If your MH's or scanners are making the same moves over and over again, it's on......
The name of the selected shape is under the grid and if you press "View" you'll see the actual figure.
Just kidding. Trust the program and your skills. I'll always look at the show, not the screen. If I didn't select the proper scanners before starting, my screen won't tell me that the wrong scanners are moving.
Most people like to have the scanners or MH's run in synchro, like me. I'm sure disabling the moving dot is a well-thought descision from Raphael. I know in the end you'll find a way to work around this.
