need fixture for stairville clb .2.4 Topic is solved
FreeStyler Version: 4.1.7
Re: need fixture for stairville clb .2.4
Post by Rod_Horning »
CLB2-4 mode 6.pff
Thank you for helping me understand.
I have made a small change to the fixture. If you would please import it into Freestyler and see if it works.
If it does not work please post a screen shot of all the windows and the output (Output, Show Output) window showing the addresses assigned to the fixture.
Thank you
alfa156
Post by alfa156 »
hi again!nothing changed from yestarday test!lo0k the print screen.to give you more informatios.when i press the speaker icon,the lamps stay on to the previus mode without do nothing.
Hi. This is a very frustrating problem. The values shown in the windows you included in your last post are what I expected them to be. Based on my understanding of the user manual, with these setting, your instrument should react to sound. Unfortunately I am out of ideas on how to fix this issue. Hopefully someone will read this series of posts and see something I've missed and be able to help you.
Christian
Post by Christian »
Can you please post the settings in the menu of the device?
alfa156
Post by alfa156 »
i posted screenshot that apear the settings
Hi alfa156. I believe that Christian wants to see the settings that display in the little window on the instrument.
alfa156
Post by alfa156 »
Did you mean this settings?
I believe so. What is the first character in the display? The 001 can clearly be seen but the first character can not. I assume it is d (for DMX) but I am not sure.
If it is d (which is the Mode) then what is the Setup display show?
alfa156
Post by alfa156 »
it is d and when i press the "set up' button shown 7 chanell and nothing else
Thanks for the reply. That is exactly what I expected. I still have no idea why your instrument will not react to sound. Can you contact the manufacturer's Customer Support and see if reaction to sound really is supported in DMX mode and if the settings in the user manual are correct?
alfa156
Post by alfa156 »
Now all works ok and the sound!! Special thanks to rod! Without you i don't know what i do!
Thank you for the feedback. You are very welcome. I am glad it is working for you.
alfa156
Post by alfa156 »
something else that i want to ask you.i have to set of stairvilles.i connect the second set via the firts set of instrument and after i go to freestyler and i set a new one icon of stairville clb 2.4 mode 6 ,i adjust d 002 (001 has the first instrument)but it doesnt work.the second instrument works only if i adjust the adress d001 the same with the first one.i have to do anything else with the freestyler?
Mode 6 uses 7 channels.
If your first clb 2.4 is set to mode 6 with the starting address set to 1 then your second clb 2.4 mode 6 would need to have the starting address set to at least 8. If you do not do this then the second clb 2.4 will react very strangely. Remember to set the starting address on the instrument the same as the starting address in Freestyler.
You can set both to the same starting address if you want to control them together identically. If you do this then you only need 1 icon in Freestyler.
Hope this helps.
kokiboki
Post by kokiboki »
Hi, i need also the fixture for Stairville CLB2.4...please.
Can you sent to me??
bojan.koltaj@gmail.com
Thanx :fs:
