Sequence Creator / Editor
A sequence can be considered as a series of several snapshots, where each DMX channel will take the desired value.
Steps can then be played during live shows, **stepped either by a time frame or in time to the music beat. **
The sequence editor is able to save / load / edit the sequences.
IMPORTANT NOTE
This article assumes you're running FreeStyler with configured fixtures.
Open the sequence editor
or use the shortcut
in the toolbar
The sequence editor will open
Create a sequence
When you launch the sequence editor, it starts with a new sequence, ready to take snapshots, so there is no need to start a new sequence. You are able to add steps with the add scene
button.
Remember that this is a snapshot, it will only record the changes made since you added the step. So if you made a change to a fixture, you might want to make sure you make the same change on the next steps otherwise it will not be recorded and another sequence may change it. (In some cases, this is desirable, like when you want to make a sequence that changes colours, but you want to allow another sequence to set the intensity.)
When you want to create a new sequence, use the new sequence
button.
By default, a sequence is limited to 15 steps, but you can change this in the Freestyler.ini file.
Save a sequence
Once you have taken several snapshots, it's time to save your current sequence so that you will able to play it during your shows.
Click on the quick save
button if you have already saved it with a name, or you can use the save as
button to give it a new name.
Enter a filename, and then you can choose to tick the add to cue and add to buttons options if you want, and click the save button.
NOTE: you can manage your sequences by creating folders (e.g. one folder for each group, or separate folders for colours/intensities/movements). NOTE: These sequence files can easily be copied from one PC to another (if you have the same fixture setup).
Load a sequence
You can load an existing sequence and edit it (insert steps, change fade, time, etc.).
Edit a sequence
When editing a sequence, you can move from one step to another with the browse steps
buttons.
You can choose to:
It's also possible to use shortcuts to copy, cut, paste or undo the current step.
With the sequence editor, you are able to:
Options
“Options…” is found in the lower left corner of the Sequence editor.
Disable fades between step
This function removes fade time between scenes during editing playback.
This is useful when long times between scenes are used and a fast scroll between the scenes in edit mode is needed.
When this is “on” the scenes appear immediately when the “Left” or Right” arrows are pressed without waiting for the steps to fade.
Remove selected fixtures from sequence
During programming, it may turn out that a fixture you've set values for doesn’t fit into your scene. With this option, it is possible to remove the unwanted fixture without having to re-make the sequence again.
Clear channel values when “new” clicked
This function clears all values by setting them to 0.
NOTE. Clear is not the same as default values.
Transparent or
Static
The sequence editor can be set to record the scenes in two modes, Transparent or Static.
In transparent mode, the sequence editor only records the channels that are changed or set to “Fade” / “Snap” in fader panels (not those set to “Off”). This makes it possible for other sequences to change the other channels not included when this sequence is running.
In static mode, all channels are recorded by the Sequence editor. This makes it possible to set the whole light to a wanted state and then record all channels.
As an example on these two modes imagine a setup where a lot of sequences are controlling various fixtures via sub masters. Some sequences control movement, some colors and other gobos.
In certain situations, the lights are to be in a well-defined setup. This could be lights on the audience and the scene in an introduction. This is set once and recorded as one static scene.
Attach the sequence to an override button and it is now possible to have all the light in various settings and then by pressing this one override button, all of the programmed lights will be set for the introduction scene.
Status of the Transparent/Static mode seen in the lower right corner of the Sequence editor.
Create 2510 file
Create a file for the Martin 2510, which is a DMX recorder that can play back sequences.
Run a sequence
Once you are proud of your design, it's time to test it.
You can use the preview
button.
When running a live show, you will find your sequences in the override buttons //(if you have ticked the add to buttons option before saving the sequence)
NOTE: Override buttons only show the first step in your sequence, and there is no fade, it just snaps to the set values.
AND in the cue list (if you have ticked the add to cue option before saving the sequence)
You can also program sequences using the FX. You can see the FX button at the top right of the sequence editor.
Learn more about FX here.
