Old sequences Topic is solved
tendril
Old sequences
Post by tendril »
Sorry if I'm being lame... have read a bit but am confused....
Want to upgrade to the new version from 2.96j but if I'm reading things right, NONE of my sequences will work in the new version.
I have 100 sequences and really don't want to have to recreate them for the new software. Is this the only way?
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Old sequences
Post by Mattotone »
that is correct.
aquas
Re: Old sequences
Post by aquas »
hi,
but Raph said that if we open the sequences in the sequence editor and save again they work correctly... and is the only way to get the old sequences!!!!
I'm wrong??
cumpliments
rick_v
Re: Old sequences
Post by rick_v »
You can use your old sequences again. You only have to open them in the editor and save them again. (Although, it worked for me!)
Maybe it is wise to try it first on another computer.
Good luck!!
Rick
Re: Old sequences
Post by Mattotone »
as far as i was aware.
the old sequences were compatible before version 3. As version 3 had a new format.
In the past opening an old sequence into the sequence editor would save in the new format. And this will also be the case with sequences built in version 3, upgrading to version 3.1
but you shouldn't be able to upgrade from v2 to v3.
Hi
Normally you can open your old sequences in the "create sequence" window and save/convert it to the new file format.
Best regards
Raph
If that means you can do it, or Normally you can but not this version is any ones guess. I have no version 2 sequences to test this.
Oxygene
FreeStyler Version: 3.0
Re: Old sequences
Post by Oxygene »
You CAN load your 2.96j files and convert them, we did that as well and all works
tendril
Re: Old sequences
Post by tendril »
Loaded all my old sequences from 2.96j into 3.01 one at a tikme and saved them. Worked a trest, but a bit laborious
