Shutter / Intensity - Problem?
Benny
Post by Benny »
I made a number of cues with PAR64 spots and MH660's:
Colorcombinations
MH Movings
MH Controls
In the MH controls there is one Cue only opening the shutter.
The cue works only on the override Buttons, but not in the submaster where i'd need it.
I've checked that this is the only cue with access to the shutter.... (Snap)
If open the cue manually, and then press play for the cue in the submaster, the shutter is closing!!!
Tried alot and alot more, but don't understand the reason for that or even howto make it work.....
Benny
aquas
Re: Shutter / Intensity - Problem?
Post by aquas »
When you create a sequence you have 2 steps, so when you put the Cue on submaster and run it, the sub run the 2 steps, one step open, and one step closed. Try to open the sequence in editor and delete the step that close the shutter. And you need to create in transparent, because if isn't set didn't rum more than a sequence at the same time, run one on a time.
Cumpliments
