First of all i have to say, that the new version 3.0.1 is great and i love to work with it!
I got some ideas for little improvements:
* Add custom buttons to the touchscreen userinterface 1.
- On the top right of the userinterface 1 there's a lot of free place where the user could add some buttons from the new userinterface 2.
- At least the tap sync button would be nice on the userinterface 1
* Chance the layout of userinterface 1
- Color 1, Color 2, Gobo 1 and Gobo 2 could be put together into one catogory, so you could select them much faster.
- The fader for the gobo rotation is great, it would be nice if you also could add faders for color, gobo and especially the strobe and dimmer function!
* CMY color panel continuous
- At the CMY color mixing on userinterface 1 the color does not change until you release the finger from the screen. It would be nice if it would be a continuous change when you run the finger over it.
I know, for you the touchscreen isn't highest priority and i don't know how easy or difficult it is to change this things, but it would be nice if you consider it for the next update
Best regards from Austia!
Tom0101
