hi i'm looking for a fixture file for the equinox virgo laser.
I am expecting a DMX cable for free styler next week so i will have a go at making one but i have no idea where to start.
Are there any howtos for this. i do not understand how to add a laser as its not the same as a scanner.
Please point me in the right direction thx
Is there a fixture for Equinox - Virgo Laser
apcyberax
apcyberax
Re: Is there a fixture for Equinox - Virgo Laser
i have been trying to get this one working but the dmx channels in the book do not seem to match.
It says 8 channels. channel 1 works as teh mode with blackout like the book says. it then says
6-Move X
7- Move Y
8- Speed
but 8 is moving the X
and channel 9 seems to be the Y
has anyone had any experence with this laser
6-Move X
7- Move Y
8- Speed
- remco_k
- FreeStyler Version: N/A
Many fixtures have a mode setting. E.g Mode 1,2,3,4.
Each mode has its own DMX adressing, wich are all in the manual.
I don't know your fixture, but maybe it set to mode 2 and you are trying to control it with mode 1 DMX assignments.
Are you sure you've set the right start channel?
apcyberax
yes start channel is 1, i haev termnated after the dmx laser.
There is not any settings other them dmx channels and one to turn dmx on and off
i ahve worked out most of the channels. seems theres afew channels between the ones hte book says that do not seem to do anything.
i hvae modes and B/O, pattens working, single shares and x/y scan
i think the book is just wrong. I will post what i have when i get it finished
