Freestyler sync
GoGoHaRrY
Freestyler sync
Post by GoGoHaRrY »
I would like to use Freestyler for my christmas daisplay in my home garden, therefore it would be nice if Freestyler could synchonize to something else than my PC clock (Freestyler 3.0.1).
When the "scheduler" time is set to a more accurate format (hh:mm:ss:ff or hh:mm:ss:uu) this field should be accurate enough for triggering a cue.
It should be perfect to set the time to MIDI timecode, Windows Mediaplayer Time, Winamp Time so a great range of possibilities appear.
Also a cuelist with more than 20 items would be nice if the cues can be accurate triggered bij timecode.
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Freestyler sync
Post by Mattotone »
this feature has been removed. try a previous version (about 3) and win amp will run.
Cues will stay at 20.
Return to “Ideas and Remarks”
