is it possible to export the dmx-data for a scene/sequence ? or is the file format open ?
i build a little dmx standalone-player to control a few LED-PARs in a restaurant/bar. My idea is, to configure the scenes with freestyler and writes a smal c-programm to convert the freestyler scenes/sequences in a downloadable format for my player.
Regards
Georg
Export Topic is solved
- djSupport
Re: Export
take alook at the file in notepad and try work it out its just a text file i think.... with a different extension
