ZQ02367 suche Fixture
london
FreeStyler Version: 2x
Post by london »
Bin neu - suche fixture für ZQ02367
Moving Head 14 CH / 18 Prismen 14 Gobos 120W
Uking oder Wiwreenm, Dongguan Tong Global Industrial, Shenzhen Zhuoqiong Technology
bzw. gibt es schon Fixture von baugleichen Geräten ? ;)
DMX Control Channel Table:
Channel 1 (000-007)White Light, (800-079)Colour 1-9, (080-151)Half-Color Effect 1-9, (152-207)The Color Wheel Rotates Forward, (208-255)The Color Wheel Reverses
Channel 2 (000-009, 250-255)Turn Off Strobe, (010-249)Strobe, Speed From Slow To Fast
Channel 3 (000-255)LED Linear Total Dimming, Brightness 0-100%
Channel 4 (000-005)Circular Pattern, (006-083)Pattern 1-13, (084-161)Pattern 13-1 Shake, Slow To Fast, (162-207)The Pattern Rotates Forward,(208-255)The Pattern Rotates In Reverse
Channel 5 (000-099)Prism Off, (100-127)Prism On (18 Prism), (128-255)The Prism Rotates 360
Channel 6 (000-126)Colourful Close, (127-255)Colorful Open
Channel 7 (000-255)Clarity Adjustment
Channel 8 (000-255)Horizontal Position
Channel 9 (000-255)X-Axis Fine Adjustment And Fretting
Channel 10 (000-255)Vertical Position
Channel 11 (000-255)Y-Axis Fine Adjustment And Fretting
Channel 12 (000-255)X/Y Moving Speed, From Fast To Slow
Channel 13 (000-009)Other Channels Have A Role, (010-014)Fast Self-Propelled, (015-194)Slow Self-Propelled, (195-255)Sound
Channel 14 (000-249)No Function, (250-255)Automatic Reset After Waiting For 5S
FreeStyler Version: 4.1.7
Re: ZQ02367 suche Fixture
Post by Rod_Horning »
Attached is a fixture that should work for you. With more details about the color wheel, gobo wheel, Clarity (is this focus), Colorful I can add additional helpful programming features.
Uking_ZQ02367.pff
(3.38 KiB) Downloaded 40 times
Return to “U'King”
