Hey everyone
I have tried and tried to create a profile for an elektralite elektrick eye and I carn't seem to control it properly. Is there anyone who could help me by creating a fixture profile for me. Im am willing to pay for the profile.
The information for the light can be found here http://www.myelektralite.com/p/p4s1s4.htm
Any help much appriciated
Gaz
Fixture profile for a elektralite eye
- FreeStyler Version: 3
- remco_k
- FreeStyler Version: N/A
Re: Fixture profile for a elektralite eye
Can't help you if you don't tell what is not working or what is going wrong.gaz the sparky wrote:I have tried and tried to create a profile for an elektralite elektrick eye and I carn't seem to control it properly. Is there anyone who could help me by creating a fixture profile for me.
Creating your own fixture in the FixtureCreator is easy. Your fixture has the most obvious and default functionality so creating one yourself should not be any problem at all.
Channel 3 - rotating gobo rotation
0-7 No rotation
8-127 forwards gobo rotation from fast to slow
128-135 No rotation
136-255 Backwards gobo rotation from slow to fast
Channel 4 - Shutter, strobe
0-31 Shutter closed
32-63 Dimmer (close to open)
64-95 Strobe effect slow to fast
96-127 No function (shutter open)
128-159 Pulse-effect in sequences
160-191 No function (shutter open)
192-223 Random strobe effect slow to fast
224-255 No function (shutter open)
Channel 7 - Speed pan/tilt movement
0-4 max speed
5-225 max to min speed
226-235 blackout by movement
236-245 blackout by all wheel changing
246-255 no function
Channel 8 – Lamp on/off, reset, internal programs
0-19 color change normal
20-39 color change to any position
40-59 Lamp on
60-79 Lamp switch off
100-119 Internal program 1
120-139 Internal program 2
140-159 Internal program 3
160-179 Internal program 4
180-199 Internal program 5
200-219 Internal program 6
220-239 Internal program 7
240-255 Internal program 8
I have got the colours,gobos and pan and tilt sorted i dont know where to input the values for the internal programs , channle 3 for the gobo rotation that will do for now
thanks for any advice
gaz
0-7 No rotation
128-135 No rotation
0-31 Shutter closed
0-4 max speed
246-255 no function
40-59 Lamp on
gaz
- remco_k
Check out the macros tab, I think thats a place to put that.
