has there been any fixtures made for the DL-22 laser or does anyone know where i can get it from
is anyone abe to make the fixture for this as i am not able to work out how to do it
i have added the manual if that helps
NEED HELP TO MAKE FIXTURE FOR SHINP DL-22
- FreeStyler Version: 3.3.2
Re: NEED HELP TO MAKE FIXTURE FOR SHINP DL-22
is anyone able to help with this
You can always pick up the 7 channel fixture created by DJ Support in the FreeStyler Fixture Files - User created Downloads area.
That will at least enable you to use the fixture until, you can either work out how to create a fixture file or someone else comes up with one.
- FreeStyler Version: 3.6
- Twitter: none
anyone have the profile for this light?
