Hello.
How can I copy fixture sequences to another fixture?
For example.
I have created sequences for 4 beams (for example 001,017,033,049), now I've added four beams too (065,081,097,113), and I want to copy all sequences of first beams to 4 new beams. I dont want to have same addresses for example, I want to copy to new fixtures sequences of previous fixtures.
Thanks.
Copy fixture sequence to another fixture
levonatayan
- FreeStyler Version: 4.1.7
Re: Copy fixture sequence to another fixture
I am not aware of an easy way to do this.
What you can do is use the copy and past channel values option in the sequence editor.
For each scene in a sequence you can select the existing beam, right click and copy the channel values, deselect the existing beam, select the new beam, right click and paste the channel values.
This, of course, is quite tedious. If desired submit a request to have this featured added to Freestyler (this is done via the Bug Tracker / Feature request system. The link can be found in the Quick Links in the upper left corner of this window. Note - this is a separate system from this forum and you must create an account. You may use the same user name and password but the passwords are not synchronized.
