Both interface at the same time
patmsrd
Just started using FS
FreeStyler Version: 4.1.7
Post by patmsrd »
Hello, is there a trick to have 2 interfaces simultaneously. One to have the show with magic 3D (virtual interface) and the other towards the interface in the direction of the lights
Re: Both interface at the same time
if you mean control the lights and use magic3d at the same time you just setup your usb 2 dmx instead of virtual and it'll still show in magic 3d, the virtual interface was just so if you haven't got it connected, for example say your not at the nightclub etc then you could still build shows at home without FS complaining that it cannot load your USB DMX
patmsrd
Post by patmsrd »
Thank's , i will try
