Hello
I have a problem with FS. In the "lamp window", in the box to the left of open and close shutter, I have the "no entry" drawing.
So, when I create sequences with switching on/off the lamps, this does not work when launching them via the Submaster.
However, it works with the sequence editor (?)
Do you know how to remove the "no entry" icon in the lamp window in front of open/closed shutter?
Lamp Windows - HELP
patmsrd
- Just started using FS
- FreeStyler Version: 4.1.7
Re: Lamp Windows - HELP
Please post a screen snapshot showing the "no entry" icon.
The test I set up ran fine in the submaster.
