Hi I have been working with Freestyle a while now and would like to do 2 things
The first is to select a cue/s by midi trigger In the midi set up list there is a "cue list tab" 1 to 6 boxes but when i input a midi note it doesn't trigger the cue. If I use the "Toggle cue list" with the same note it works! can anyone help me to get the "cue list tab" option to work.
And the second is to find a way to reset all lights and sequences to off/ stop/clear etc from 1 midi trigger note. ie to clear everything before the next song etc
Thanks in advance. Richard
trigger cue list via midi and reset/clear all sequences via midi
rcomfy
- FreeStyler Version: 4.1.7
Re: trigger cue list via midi and reset/clear all sequences via midi
Re: "reset all lights" - one way is to create a Sequence that performs the action you want. Assign a MIDI value that starts that sequence. Just remember that, if MIDI is active, anytime that note is played on the MIDI device this reset action will happen so choose the MIDI note carefully.
