File Already Exists
Gibbie
File Already Exists
Post by Gibbie »
I am trying to rename a submaster but when I enter the new name I get a popup - File Already Exists.
None of the existing submasters have been named and I've tried clearing all of the submasters first.
Any ideas? Thanks!!
FreeStyler Version: 4.1.7
Re: File Already Exists
Post by Rod_Horning »
Please use the Backup/Restore function to create a backup of your Freestyler. ZIP the file and post it in this thread. I tried several things and could not duplicate your issue. I will restore your Freestyler to my computer and see if I can find the problem.
Gibbie
Post by Gibbie »
The backup file is attached.
Thanks for taking a look.
FileAlreadyExists.zip
(1.23 MiB) Downloaded 79 times
I could not replicate your issue.
The attached jpeg shows the submaster window after I restored from your backup, started Freestyler and opened the sub-master window. I see two submasters - one is named basement and the other has a null name as only the file extension shows.
The second attached jpeg shows the CUE list named basement - interesting that it only has 1 Sequence.
The third attached jpeg shows the CUE list named cc.
How are you trying to rename the sub-master? There is no rename function on the sub-master window.
screen_shots.zip
(425.34 KiB) Downloaded 68 times
Gibbie
Post by Gibbie »
The reason for the lack of sequences or cues was that this backup was created to show the error I was getting, not the show file I typically use.
I deleted the cc CUE list as I'm not sure how it was created so it was not needed.
I may have discovered the reason I was getting the original error. I was trying to rename the submaster prior to adding any sequences. I understand that the typical process would be to build and save the cue list and then load those into the submaster. I was attempting to build the submaster first.
So if I try to rename an empty submaster by clicking the submaster title, I get the File Already Exists. If I add a sequence first, the rename process works fine.
Thanks for verifying that it worked properly on your end.
Thank you for the update
