If someone can help me please?
Search laser Fireworks Pro
badflo84
- FreeStyler Version: 3.2.8
Hi I search this fixture, i have the user manual and i try to make it but it doesn't work.
fireworks_pro.pdf- (1.24 MiB) Downloaded 157 times
- FreeStyler Version: 4.1.7
Re: Search laser Fireworks Pro
Working on it. My schedule is very full for the next few days so please be patient.
badflo84
ok thank you, don't worry i'll wait
Attached is my attempt.
I used Gobo1 and Gobo2 to give you a shortcut to the Oscillation Modes of the 2 motors.
The Color wheel will control the Laser colors and which of them strobe. The strobe channel (and window) controls the strobe speed.
Freestyler really does not recognize lasers so I "bent" the fixture usage a bit but it should work.
Your feedback will be greatly appreciated.
DUNE_LAS150FW.pff- (57.77 KiB) Downloaded 111 times
badflo84
thank you, i try it and i made you feedback
