Lights Doing Weird :s BUG !!???
LJ Robin
Post by LJ Robin »
Hi ,
I downloaded the 3.0 and when I move pan & tilt , they don't do it fluencely . Every moving head in 3D is shaking. With the scanners I can do it.
I don't know if it do in live but in the 3D the do it.
I read that my shows from the older versions need to be renamed to .chb , I did this but when I do the show all my effects are flipping .
Fs detects also mor than 10000 steps in 1 show :s
I hope someone can helpe me
Greetings and sorry for my bad Enlgish but I'm from Belguim :fs:
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Lights Doing Weird :s
Post by Mattotone »
Old shows are no longer compatible.
unfortunately they will have to be recreated.
LJ Robin
Re: Lights Doing Weird :s BUG?!!!
Post by LJ Robin »
Ok no problem , but when I move my movinghead , wethever it is a I-move from JB Systems of a VDP 250 MH7 from HQ , they wil move in pieces and doing crazy , anybody a solution?
Also when I use the bezier shapes.
Greetings Robin :fs:
On the video you will know what I mean :http://www.youtube.com/v/7JJDntQ5ovk
I installed FS on 3 other computers withs different xp and the same , also with other movinghead , scanners are not a problem . Is this a bug or something?!!!
