Adjustable Fog Control
magic
FreeStyler Version: 4.1.6
Post by magic »
First let me express again, I really like Freestyler a lot and a thank Raphael / team a lot for all the efforts and devolpment.
My idea/suggestion is a follows.
Let the Fog Control be more customizable. Having a Hazer most of the time the 15seconds fog/haze time max is too short.
Fiddling a lot with separate hazer cue’s. Yes it works but I notice that the amount of haze is different so now and then. Being able to just use the Fog/Haze control would be really welcome.
FreeStyler Version: 4.1.7
Re: Adjustable Fog Control
Post by Rod_Horning »
You should make this request in the Bug Tracker / Feature Requests system. The link to that system is the first link under Quick Links which you will find in the upper left hand corner of this page.
You will need to register in that system also. I use the same user id but that is not a requirement.
Return to “Ideas and Remarks”
