Number of macros in Fixture Creator
- colombo
- FreeStyler Version: 4.1.7
Hi. I have not found a satisfactory answer to the question of what is the maximum number of macros in Fixture Creator. I cannot create more than 150 of them. Is it possible to set a larger number of macros somewhere? 150 macros is not enough for today's lasers.
Re: Number of macros in Fixture Creator
I do not see a value in the .ini file that would increase this number. You should probably submit a change request via the Bug Tracker link. This link is found in the Quick Links at the top left of the page. You will need to register in that system also.
Are the laser patterns controlled with just one channel? If so you might be able to call that channel either a GOBO or COLOR wheel which get you a few more "macros".
- colombo
The laser has banks, from which the displayed pattern is selected.
