Input past end of file issue
jffj41
Just started using FS
I Use FreeStyler for: Band
Post by jffj41 »
My system has been set up for a while. I have 4 moving heads and 6 par cans for our cover band. Lately I have been using the par cans. We have a new years gig and I decided to break out the moving heads. When I pull up the location that has the moving heads that were working fine. I get the "input past end of file" error message. The moving head gifs do not appear. The names and addresses are in the setup file with the correct dmx addresses. These are chinese Tomshine 80w moving heads. When I open the fixture profile, zoom rotation is set to 192 and is in red. Also animation disc rot is set at 190 and it is red as well. Can anyone help with what is causing this error? Everything worked fine that last time the full system was used. Thank you in advance!
jffj41
Re: Input past end of file issue
Post by jffj41 »
Ok, I have upgraded the software several times and it looks like it corrupted the fixture profile. I reloaded the profiles and my problem went away. I hope this helps someone!
