Fixture help
Raven Lunatic
Fixture help
Post by Raven Lunatic »
Hi I am very new to the world of DMX
I can't seem to get S2L to get random DMX values for my fixture.
I can manually change the values using the sliders within freestyler and it works great.
S2L detects the audio just fine but freestyler does nothing. I have selected every option to react to sound within freestyler but I get nothing.
I think its a problem with my fixture file that I created.
Littleboyny Party Light.pdf
(448.92 KiB) Downloaded 525 times
littleboyny Party lightt.pff
Fixture file
(546 Bytes) Downloaded 540 times
MrSleeps
FreeStyler Version: 4
Re: Fixture help
Post by MrSleeps »
See if the attached file makes any difference?
(556 Bytes) Downloaded 509 times
Raven Lunatic
Re: Fixture help
Sorry I did not get a message about your reply.
Thank you for taking a look at my fixture.
Between now and posting I have moved to Ubuntu Linux so I am unable to test the file :-(
As it happens I uploaded my party light pdf into Microsoft Copilot and it spat out the following config for Freestyler DMX to copy into a pff textfile.
; Freestyler DMX Fixture File for Littleboyny Party Light
[Fixture]
Name=Littleboyny Party Light
Manufacturer=Littleboyny
Model=Party Light
DMXChannels=11
Type=Moving/Party Light
Notes=A party light featuring multi-mode operation, laser channels, motorized effects, LED colors, and a flexible strobe function.
[Channels]
; Channel 1: Function (Special Channel)
; 000-030: No Function
; 031-070: AUTO Mode
; 071-110: LED Gradual Change
; 111-150: Flash AUTO
; 151-190: DJ Sound
; 191-230: LED DJ Sound
; 231-255: No Function
Channel1=Function ; Full range 0-255 with subranges as above
; Channel 2: Red Laser 1 (000-255)
Channel2=Red Laser 1
; Channel 3: Red Laser 2 (000-255)
Channel3=Red Laser 2
; Channel 4: Green Laser (000-255)
Channel4=Green Laser
; Channel 5: Blue Laser (000-255)
Channel5=Blue Laser
; Channel 6: Motor Speed (000-255)
Channel6=Motor Speed
; Channel 7: UV (000-255)
Channel7=UV
; Channel 8: LED Red (000-255)
Channel8=LED Red
; Channel 9: LED Green (000-255)
Channel9=LED Green
; Channel 10: LED Blue (000-255)
Channel10=LED Blue
; Channel 11: Flash/Strobe
; 000: OFF
; 001-004: Basic ON
; 005-029: Random Flash
; 030-255: Flash Speed (slow to fast)
Channel11=Flash/Strobe
; End of fixture definition
I got a similar file output for QLC+
Thanks again!
Raven Lunatic
Re: Fixture help
Just discovered QLC+ does not do S2L.
FreeStyler Version: 4.1.7
Re: Fixture help
Post by Rod_Horning »
Try the O2SL plugin, which is compatible with many DJ applications and allows you to trigger lighting effects directly from audio signals. Additionally, you can assign the LINE IN port in QLC+ as an audio input to use an external music source for sound-to-light effects.
