Problem after change laptop and update Windows
fokus01
FreeStyler Version: 3.4.6
Post by fokus01 »
Hi folks,,,at first,sory for my bad Englis 😁
I have problem with Freestyler software; l had a old laptop with Windows 7 for couple of years and ewerything was 👌
Yesturday l gotma new laptop with Windows 10 proffesional Os.
I was create backukp on old lap ( thare was 6.1.1 version),install a Freestyler on new laptop ( l think is 6.1.6) ,copy got from old to new lap,,, and here isnproblem with created scens; moving head not work smooth as on old lap ( Windows 7),they hawe some kind of pauses in moving,sometime created scenes glitch/stuck on couple of created steps in scen,and then suddenly keep going normali thrue the xreated scen and so...
I was download and install Dmx driver's,,,,ewerithing seems ok in settings butt program not working how it should. Any help please 😄
Tnx
Best regards
FreeStyler Version: 4.1.7
Re: Problem after change laptop and update Windows
Post by Rod_Horning »
What DMX interface are you using?
FreeStyler Version: 4.01
Post by Partyman »
Make sure you have dot net 3.5 installed and also ftdi drivers
