shape problem (bug?)
FALCETTA
- FreeStyler Version: 3.5.6
good evening, I've been trying to create scenes with shape crator for about 4 hours without results, I'll start by saying that I've always used it and I've never had any major problems... I'm using the latest version of FS. I basically wanted to create sequences with shapes (circle, twist etc..) but I don't know why, once I saved for example a step with circle. when I went to reproduce the sequence, it made another movement. as if it hadn't taken the data. sometimes instead after several attempts to save overwritten it worked.. I tried with another shape for example twist, saved and again the sequence didn't correspond to the saved twist but it always made a shape that I hadn't saved, I don't know if I managed to explain myself well. in a few words I saved a step. with a shape, and when I tried to reproduce it, it made movements that had nothing to do with the saved shape ... please help me otherwise I'm desperate
FALCETTA
Re: shape problem (bug?)
please help !!!
perrip
- Commited FS Forum helper
- FreeStyler Version: 4.1.7
I have often made a scene with the shape creator and have not had the same problem. Is it a single step scene with just the fixture or groups of the same fixture, and no other lights? it sounds like some other cue you are running is interfering. Start simple to isolate the problem. one fixture one cue running one shape and another cue running another shape and then go back and forth with them. let me know how that goes.
patmsrd
- Just started using FS
Bonjour, j' ai un probleme similaire avec l' enregistrement de tout type de séquence. Pas seulement les shape. J' etais sous W10Pro et ça fonctionnais correctement. Depuis que je suis passé sous W11 familliale, c' est n'importe quoi pour les enregistrements de sequences. Je galère aussi. J' ai posté un message sur ce groupe a ce sujet. Vous êtes sur quelle version de Windows et de FS ?
