cuelist submaster
FALCETTA
FreeStyler Version: 3.5.6
cuelist submaster
Post by FALCETTA »
Good afternoon, I'm reading and rereading dozens of posts on the use of submasters, but I'm still not very clear on their function and what the advantages of using them might be.
Is there anyone who has the patience to explain to me, perhaps with some examples? A thousand thanks !!!
FALCETTA
Re: cuelist submaster
Post by FALCETTA »
Nothin ?
perrip
Commited FS Forum helper
FreeStyler Version: 4.1.7
Post by perrip »
Oh boy, I have used just cue lists and just submasters. With submaster I feel like it allows you to have a more dynamic show, and change things up at the last minute. For me like doing a live band show and not knowing the set list. you can have say your main wash lights in a submaster with a variety of diferent colors to change to for simplicity a submaster that contains clue lists of main wash lights one just red, one blue, one white. and you can have your say movers in another submaster, with different cluelists that contain, movers in a pattern with white, a pattern with red, a still pattern on center stage, a blue pattern. you can then say keep your wash lights on white and change the movers color easily. with submasters you can also dim groups of lights, so you can dim your movers in and out as the wash lights stay the same.
Hope that helps.
edsfernando1
Instagram: edsfernando1
Post by edsfernando1 »
É um recurso muito interessante. Imagine a situação onde você precise controlar a intensidade de um grupo específico enquanto mantem outros aparelhos no máximo ou intensidades diferentes. Assim, tu não precisa ficar selecionando cada um deles para realizar esse controle.
perrip
Post by perrip »
so do you feel like you know about submasters yet? not sure what the last reply said (sorry only speak English) main benefit for me is controlling and dimming select groups of lights. of course with Freestyler and any lighting software there are a lot of ways to do different things, it depends on what works for you.
